Non Starting on Cold mornings.
Doosan
As the title, I go out to my Rav (All frosted up) and try to start the engine, it try's to fire but not enough to start. Now when the sun has been on the car for about 2 hours and the temperature has gone up, over zero the Rav starts fine. Also if I spray easy-start into the air intake it starts straight away. Can anyone help me with this problem?
TIA
A faulty sticking suction control valve is well known to cause cold start issues where either extended cranking or warmth are required to start the car, this is subject to a TSB from Toyota EG-0132T-1110-EN and requires a modified Suction control valve kit 04226-26030 and an engine ECU software update.
See HERE
