My 2004estima hybrid had Battery replaced last year as the one that was on was too small and I ended up having to jump start it several times. Since Battery been replaced by proper sized one I've not been able to find a diagnostic machine that can read it . Before jump and Battery change it read an communicated with diagnostic machines fine. Any clue how to remedy this?
Check the OBD2 fuse ?
Thankyou again flash22 ,no idea where this is , will I find it in handbook? You don't happen to know where I could get front struts from too?
  • 3 months later...
On 1/20/2023 at 4:09 PM, flash22 said:
Replied to your other thread
fuse - drivers side on the A pillar-ish
https://fuseandrelay.com/toyota/estima-previa.html
Couldn't find any fuses under drivers side ,all seem to be under bonnet that I can 🙈
As per the link, it's on the driver's side above the kick panel, the fuses are behind a small black cover, there is another fuse box on the passenger side
click to enlarge
