10 mm bolts
John16
hi all
quick question pls :
i removed the driver under the wheel plastic ( left wheel drive) .
it was held with 2 10mm bolts i removed and forgot where from
one was where the green circle  is , where the other one goes pls ?
thats the bolt i have unscrew.
mayb it belong to the rubber gasket around the driver door ?
i took it of too...can b from there
John it’s a good idea to photograph each stage of dismantling, particularly if you haven’t done it before or if the old memory is dodgy 🤔
That looks like one of the bolts that hold the cable brackets or earth point
edit. had a quick look at some pics, it's the lower dash mount bolt
from techfreak's thread (top right) this is RHD
IMG_20220511_185433.jpg.c6432a99d9b2a5c2
IMG_20220511_190216.jpg.d55ac6842b5f8a39
