Please Help; Car stalls, loss power after 60mph speed. Auris Hybrid 2014
PPIP88
After driving 60mph car keep stalling, steering lock, no power then complete stop. Following has replaced and checked 1 by 1 which is EGR, INLET MANIFOLD, THROTTLE BODY, FUEL PUMP, HYBRID Battery, FUSE & RELAY. Please help me.
17 minutes ago, PPIP88 said:
After driving 60mph car keep stalling, steering lock, no power then complete stop. Following has replaced and checked 1 by 1 which is EGR, INLET MANIFOLD, THROTTLE BODY, FUEL PUMP, HYBRID BATTERY, FUSE & RELAY. Please help me.
You have thrown a lot of money at this car including the price of a Hybrid Battery, did you ever do a diagnostic check on it??
Sounds like the damper is a failing under load - how come it wasn't diagnosed properly and was shot with the part's canon ?
After that much of work has been done whoever worked on the car should be liable for questions.
If the car behaves like that were there any fault codes ?
What exactly was changed here. ..?
What is the mileage of the car?
Diagnostic codes first and we can take it from there. If the clutch goes should be “ hybrid system malfunction “ error registered imo., but check what you have first .
Those are like replacing 1/2 of the car out. 60mph lockout is very dangerous. You must check what code do you have, are all recalls had been performed?
I believe it is caused by Inverter unit or a problem with wiring/fuse/relay. The fuel pump problems usually goes to limp mode first.
