Hello, my wife's car is a Toyota corolla 1.6vvti from 2004 automatic and the brake lights don't work, none of the three. The fuse under the dashboard is OK and the bulbs are also OK. Is there anywhere another Dus or what could be the pro lem?
Yes, brake switch on the the brake pedal . This should be a plastic or metal part attached to the pedal.
 They can go wrong in two ways, constant brake lights ON or no brake lights at all.
You can check that and replace.
thanks, I will check this in the weekend. I presume it's an easy job to replace it?
How can i messure the switch is faulty?
you can use perhaps this video as tutorial. 👍
The switch can also physically break, like getting stuck in open or closed position.
8 hours ago, Timmy 269 said:
You are welcome
