Can't see it in the manual and before I go taking the car apart does anyone know where the fuse  for the front auxiliary socket outlet is please (the one in the armrest compartment)? The plug from my tyre inflator disintegrated whilst plugged in and I think the fuse is blown :blush:
It should be in the passenger footwell fusebox. Pop off the plastic cover above the footwell and then the fusebox will be visible near the A pillar. This is the fuse layout of mine - albeit a 2019 Excel. It should be the P/Outlet No1 fuse. Just check the fuse location hasn't changed from this picture.
