Auris 2014 - nav from 2018?
klash997
Hi fellas!
Is it possible to retrofit the nav from 2018 to a 2014 ?
It sure look like it would fit even though it'll be a mix-match with new and old.
Thing is I recently bought the car, thinking it had GPS but turns out it didn't.
I can get the newer navi with gps-harman box cheaper than the pre-lci one.
It is always better to get non toyota brand GPS that is often overpriced for the map update. It cost roughly 50€ per year which is insane. I would rather plug my TomTom GPS that has livetime update and more reliable map apps including all speed camera warning.
But I believe we can use the infotainment from different year as long as they have the same version Touch and Go type.
Thats a legit statement if one need up-to-date maps. Personally I really don't need it as our road network has been kinda static for ever. A few new neighbourhoods here and there but no major update so to speak.
I have not ordered the facelift navi yet. Cant buy the navi with opportunity to return so i'd love to confirm before I order it
I fitted Touch 2 & Go on my 2013 that had Touch, never had gps.
For me the physical fit was no issue, however I had to diy some of the wiring and I think the antenna.
Everything clicked into place except the connector for the rear camera. My car had 16pin connector wired in, but the Touch 2&Go has 24pin, so I used jumper cables to wire it, have a look my post on the diy. I did buy the parts but never got round to making the adaptor cable.
Touch 2 & Go isbfrom 2014 so you might be ok but double check.
I am sure someone more knowledgeable than me will comeband confirm.
Wow thats awesome! Finally someone!
So I dont misunderstand, every thing clicks in place correct alining with the Pre-facelift fascia (plastics) or did u get the lci fascia and mosofied it aswell?
All but the rear view cam? That sounds the !Removed!! Thanks!
No modifications to the facia/dash trim.
I'd do some homework if I were you...
