I picked up my BZ4X last week and the heating is not great, but I only have a petrol car to compare
mat best the air is warm
any help would be appreciated
Have you turned the temperature up.....?
The heating does take longer to kick in as the heat pump builds, but once it does, it feels like any other car.
Agree with Matthew, it does takea few minutes for the heater to get going.
If you turn on the Heating&Defrost remotely with the My-T app beforehand then the heater is up to temp when you get to the car.
We had the temperature set to 24 degrees C, but it got super warm so had to turn it down.
We've foiund the heater to be excellent, but the range takes quite a hit when using the heater
it drops almost 30 % range in Northeast(NJ) when temperature below 40F.
Hiren
