Ok, this engine is in my friends mr2 and my other friend and i was tryin to figure out what engine it was since he has a turbo hood but no turbo engine. Also it seems to small to be a DOHC. He MR2 is a 1993 i think. Thanks for all your help
thats a 2.2L...
are you based across the pond in America/Canada?
5S-FE
Was only fitted into the Camry over here!
2.2ltr mr2 ????????
Its the 5SFE, the amercian version of the 3SFE. Its built on the 5S block which is 2.2 litre. I assume its the same as the 3sfe as it has the single cam FE economy head.
Matt.
What Matt said .. and is faily pants ..
...it's an engine!
Sorry, just come back from pub. Quite p*****d. :wacko:
My sons Celica had the 5S-FE definately not as revvy as the GE but its got plenty of torque. They are twin cam ( so is the 3S-FE) its just that the cam belt only drives one cam, the other is gear driven off that. Apparently with a bit of work you can fit the GE head which gives plenty of power and good torque.
however it is from the 'S' series so i wonder if a GTE head could be bolted on. voila a 2.2 turbo.
ok ill get me coat
5S-FE, and isn't it something like 135bhp, yeeeeehaaaaa
Thanks for all your help guys, one more question is this a DOHC engine though?
Yes definately twin cam. The cam belt drives the inlet cam and the exhaust cam is gear driven off that.
Interesting, you think you know a car....... i guess you do learn something new everyday.....
