Outside Window Door Belt Weatherstrips
I need your help, my IQ has old rubbers, the ones that make it impossible to get water or sand inside the doors!
I wonder if you can give me a suggestion of where I can buy them?
Obrigado,
Gonçalo
2 hours ago, PCM said:
Hi PCM,
They only ship to UK Mainland, i'm in Portugal.
I was trying to avoid Toyota Portugal because of the price, but I'm finding it difficult
Thank you very much. I
I doubt you'd find a third-party weather strip for the door. Save up some money and get it from Toyota Portugal - or import it through someone like Amayama, but it may not be cheaper. You'll get the best quality from Toyota.
Posted (edited)
This is the weatherstrip that goes around the door opening in the body of the car (i.e. not the one on the door):
62311-74010    Weatherstrip, Front Door Opening Trim, Rh
62312-74010    Weatherstrip, Front Door Opening Trim, Lh
This is the seal that sits on the door:
67861-74020    Weatherstrip, Front Door, Rh
67862-74020    Weatherstrip, Front Door, Lh
Use these part numbers as a starting point, and make sure you get it verified by Toyota before ordering.
Edited by APS
Added further part numbers
