Window washer pump fuse location and number?!
cr4ig
Hi there...new to here and looking for some help.
I have a 2021 Yaris and I'm having trouble with my window washer pump. When I try to wash the windows no water comes out and there is no noise of the pump attempting to run!
I have looked to see if it may be a fuse issue but can't find a fuse for the pump alone. My front window wipers are working. I was hoping that it may just have been a fuse problem after the cold snap weather.
I should mention that neither my front or back washers are giving out any water...
Have you had a look at both locations for fuses. As well as the one in the engine bay, there’s one behind the glove box you will have to remove the glove box to get at it. Other Yaris owners may chime in with more information.
The washer fuse is in the box on the right side under the bonnet. It’s a 15 amp fuse. It’s at the end of the row of fuses at the front of the box marked up as washer under the lid. Mine blew a few weeks back when the nozzles froze.
Moved to the Yaris forum.
  • 3 months later...
On 6/6/2023 at 7:29 PM, Johannes_M said:
Have the same issue/symtpoms.
Indeed my 15A fuse is broken.
Currently trying to find a replacment. Seems to be "low profile micro blade" (?)
This one seems be alright: https://www.autodoc.co.uk/hella/945547
Quick update - received the above fuse today. Fits and works perfectly, looks also almost identical to the others.
Problem fixed for £15 - washers work again!
(No mechanic / workshop wanted to see our car because we imported it as LHD from mainland Europe...)
FWIW: I ordered 3 of the above fuses to make postage worthwhile  (shipped from Germany?) and have a backup, but went very well.
