help regarding diagnosis code/abs problem
timothy11050
hi all hopeing someone can help, i'll start the problem from the top. im a hilux virgin so go easy on me
purchased a toyota hilux 2002 (mk5 i believe) with engine management light on and in limpmode.
plugged in my diagnostics and it wont connect..pressume this is normal? anyhow did a manual test on jumping connectors as found on google ( https://procarmanuals.com/toyota-hilux-fault-codes/amp/?fbclid=IwAR3DmoHJN4i41lHfsULElgc4xl2XiIyoyyAmb9cyJzBCWyiahWUhxrif8TA )
which comes back with code '78 Incorrect change in the signal from the rear left wheel speed sensor'
i have found lh and rh sensors for sale General image of a LH rear ABS Sensor on vehicle - Plug type without loom
but my truck doesnt have these? or a loom going there? can anyone help? is the code wrong?
Pre 2005 diesels are K-line not all tools support it or support early obd2 diesels - the cheaper tools only do can bus
Can you PM me the vin/frame number
