Toyota Estima 2013 Head Unit Help
MAYUB
What is the model number of the original radio ?
These cars are jap imports they use a standard ISO for FM as can be seen in OP's posts, those adapters are not required for this application
op has the camera working, it uses a 4 pin connector, not the usually ones £25-£30 vs 10 min to tap and solder 4 wires
AS these are JDM cars all the technical info is in Japanese
Panasonic NHZN-X62G  7605`
On 3/5/2023 at 2:59 PM, Ian Lemmy kilmister said:
Thanks Ian for the link and information. I think after the long debate here, I understand now the OEM head unit has Amplifier built in to boost the radio signals but for after market unit you need signal to amplify AM and FM radio signals with additional small device which I will try and report back here.
the amplifier for FM is in the antenna base it is fed by pin 8 on the 10 pin connector
Make sure the antenna power is turned on in the setting and verify in the 12v coming from the radio
Just take the Blue wire on the adapter and Connect to 12v.
  • Confused 1
It does not use an adapter, please read page 1
OEM radio
As you can clearly see, it uses a standard ISO aerial plug
OEM radio
5 minutes ago, Ian Lemmy kilmister said:
What do u News? What is the question?
  • 1 year later...
On 9/28/2023 at 4:44 AM, 54918ss said:
Anyone have a clue to what these stereo pinouts are? They don’t match any website that I can find. I have a Toyota Estima 2013 ACR50
On 2/16/2023 at 8:00 PM, MAYUB said:
Thanks for your reply, I did some search and found a mating connector for new unit from Halford. I will remove the original fitted connector and solder wires to new connector and will report back here that how successful was the experiment. I think normally you have problem with steering switches operation with Chines head units but will report with pictures.
Toyota estima 2012
what is cable colour for SWC key 1/2 and SWC GND?
mine connector already cut so not sure which cables or SWC as mine steering wheel control not working apart from this everything else working fine, need help with SWC connect
