Suzuki Across Roof Rail Leaks
displaced
Having read the nightmare stories of the cost to repair after the roof leak issue, I was wondering if there was any preventative maintenance could be undertaken?
My warranty is up in October anyway, so formulating a plan for around that date.
Hi Derek, I haven't seen a great deal of posts or info on this issue, don't know how widespread the problem is ?
Hi Derek, not sure if you have a powered moonroof fixed but came across this video on maintenance on the moonroofs. It's worth a look because it highlights the problems that can occur and what to do. Hope it helps.
https://youtu.be/wUkq3IQfUtA
Presumably your Across is older than the 2023 shown in your profile  - please confirm when the vehicle was first registered as that should be the year in your profile.
2020
This is the post today got me worried about it:
https://www.toyotanation.com/threads/rav4-2019-water-leak.1716221/
Thanks for this. The problem I've read about is the roof rail mounts allowing water ingress - not specifically the moon roof.
I don't have the problem, just wondered if there was a pre-emptive fix.
Thanks again!
nor has anyone else on this forum as far as I can tell ... that doesn't mean that it can happen but it is hardly a widespread issue for RAV 4.5s in the UK. UK RAV 4.5s are built in Japan ...
... the quoted report suggests that it may be a problem in the US. US RAV4.5s are built in Canada.
Maybe? 😉
Thanks, that's reassuring. I'll leave off the preventative maintenance as I could just make it more likely to occur!
The moonroof isn’t available on the Across - no options are other than paint colour and a few dealer fit baubles. The roof rail leak issue is (as otters have stated) related to a particular factory which does not supply the UK.
Maybe? 😉
Had zero moonroof leak issues. Utterly torrential rain up here in the NW and Lakes. Not a single drop. Open and close the moon roof all the time from April to August so in use a lot. Plenty of opportunities for dirt and bits to cause issues but no problems at all. Whereas my Peugeot 3008 hybrid4 GT 300 was leaking from the start. Dealer tried probably 8 times to fix and 4 different approaches and mods. Made zero difference. Gave that carbage back in the end but there are dozens of suffering folk on the Pukegoat forum.
I had a Peugeot back in 2003. Never again! Besieged by automatic gearbox problems. It had two new gearboxes within a year due to rough gear change. First gearbox destroyed itself. Time would reveal the AT4 to be the biggest piece of junk ever built.
