Front camera circuit C1A0
ASAFBH14
I start the car and after several hours or sometimes minutes depending on the weather, when there is a strong sun the fault starts after a few minutes after starting. At night the fault can appear after a few hours.
The fault is a yellow triangle + warning light of a vehicle colliding with another vehicle and messages of RSA malfunction, headlight malfunction, LAS malfunction.
I cleaned the windows and the car, I haven't had an accident with the car recently.
What I did was I sprayed, DW40, on the front hood lock. I changed the lamps in the cab above the driver to strong LED lamps.
I contacted a friend who has a garage and he connected a scanner device and he got a C1A0 code of a short circuit for the front camera.
If anyone can help me understand the extent of the problem and possible solutions.
Thank you
C1AA0 ??
Is an internal fault with the sensor, It's either a sensor going bad or a wiring/connector issue also check ECU-IG No.3
if you do change the sensor/camera, it will need initializion (if new) then be sure to perform Recognition Camera/Target Position Memory and Recognition Camera Axis Adjust.
