Estima ACR30 power steering hose needed
As Above, does anyone know if the Previa version will fit, unable to find one in the usual places. Arms are getting sore
What one do you require, the one between the res to pump, pump to rack, rack to cooling loop or cooling loop return to the res ?
There are 2 listed for the Pump to rack, the split date is 04/2003
After having a closer look it's the S shaped return hose that needs replacing, in the UK and can't find one anywhere, wondering if a generic 10mm hose would be ok to replace it with
44412-58020  s shaped pipe between the rack and hardline - if you do go with a length of pipe make sure it's fuel resistant or hydraulic rated, ATF/PS fluid will eat normal rubber
Thats what I'm thinking, is it 10mm internal do you know? Thanks for your help by the way! 👍
