2013 yaris high beam !
fred1955
Hi - having a problem with the Yaris failing to light up high beam   -    both bulbs ok;  relay out and tested on a circuit so ok;  fuses all ok   -   take it to a dealer and they will only test what I have done,  so has anybody had problem with high beam not working on switch and flash .  Oh,  had the covers off the control stalk and every thing seem ok there.  Thank for any reply Fred
on a 2013 it uses the DIM relay (not the main relay) and 2 10a fuses H-LP RH HI AND H-LP LH HI and 7.5a H-LP MAIN
other fuses to check are 15a dome, 5a acc, 5a ecu-ig No.1 and 5a ecu-b No.1
How did you test the bulbs ? If you tested with a meter, did you check the resistance as well as continuity, bulbs can blow but blow closed - change the bulbs
Moved to the Yaris forum
