delete EGR
xrhstosgr
Hello
After my Auris diesel 2012 1364cc (213,000 km) misfiring symptoms (doesn't rev up) I decided to delete from the brain and then tap (bypass) the EGR valve. CODE: 25800 33010, the metal cap was placed on top of the EGR valve.
The erasure work was done by a brain programmer, while the taping - simple work - was done in the car workshop.
This move was suggested to me by several technicians (even snipers) in the past and so I have now completed it.
On the dashboard of the car there is no indication, no code that gave me the signs I described or anything else.
I have driven about 130 kms testing, and the problem remains, the car has no power, will not rev above 2000/2300 rpm in fourth and fifth, even after this work.
I think the car is not letting it go, but what else could it be? As the same symptoms remain
Any opinion would be appreciated
  • Sad 2
when was the fuel filter last changed ?? Check all the turbo intake and pipework to the intercooler
As it's a VNT turbo, the vanes can sometimes get stuck, i would scan it for codes again
a blocked cat and/or dpf can cause it not to rev
Good Evening
Blocked cat '' Do you mean my egr valve friend?
I changed the diesel filter 950 kilometers ago
DPF has deleted and removed from the brain
The car you find in the local workshop for exams all day today
