Touch up paint.
Tompaine
Hi, can anybody recommend a good quality touch up paint. I've got a stone chip in the centre of the drivers door. I'm a novice at this game so any advise would by gratefully received. Thanks
you can try this seller on eBay. I had purchased before touch up and did match the colour very well. You need to find your car colour code usually displayed on the door shut label. https://www.ebay.co.uk/itm/164071270266?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=_ejaT64KQiK&sssrc=2349624&ssuid=p34UK1z2T4m&var=&widget_ver=artemis&media=COPY
Hi Martin,
Halfords do a 2 set touch up already made up.
It depends on how deep the scratch is will determine how well it will look.
We had a few stone chips and was advised by a national mobile repairer not to use the lacquer and just use the top coat. The reason was if it had not gone through to the bare metal the application of lacquer can cause high spots which need to be rubbed down.
I took his advice and cleaned the area and applied the top coat with the very fine brush supplied. It worked and can't notice them at all now.
Obviously if they are to deep you will have to use both lacquer and top coat. The set also comes with a small abrasive for rubbing down high spots. Just get you colour code from the door piller.😁 Hope this helps
