Toyota yaris 1.8 sr mild restoration begins
dankernow
Needs a machine polish on the doors, but it's looking nice.
Some new outer lower door seals fitted this morning. The old ones were cracking and splitting. It's the small things that make a difference 20230514_085622.thumb.jpg.00125f60de78e565d440beabc00dc4f6.jpg20230514_091853.thumb.jpg.6060302ea402608edefac44bab9b5d9e.jpg
Another quick improvement, genuine toyota gear knob
  • 4 months later...
Just another update on the restoration project on the yaris 1.8 sr.
I've decided to focus on just purchasing parts from Toyota whilst most parts are still available. Some parts I've bought are OEM purely from a price perspective.
Here is what is already purchased...
Genuine toyota parts
Headlights
Rear exhaust back box
Shocks, struts, all bearings, bushes, nuts, bolts, washers etc
All brake hoses, some brake lines
Water pump, v belt, oil pump, brake master cylinder, clutch cylinder, hoses and bolts etc
Several gaskets for the side skirts, cylinder head, door seals, outer door trims
New wing mirrors, covers and trims
Interior plastic trims, gear knob, instrument cluster cover, etc
Wheel bearings, knuckles, back plates, various bolts. Brake caliper rebuild kits.
Rear beam bushes, bolts.
Fuel filler neck, rubber hoses, some fuel lines, fuel cap.
Engine cover, ventilation hoses, lots of clips, nuts, screws and bolts in the engine bay. Oil sump and bolts. Dip stick, various tubes and fittings
Various sensors on the engine
OEM denso alternator and starter motor with genuine bolts
KYB springs
Parts on order are:
Radiator and some hoses
Rear lights and fog lights20230507_063303.thumb.jpg.b47018ee5e809eb0f2787e5b189a07ab.jpg
Lot's more to order, front section of exhaust, control arms, drive shafts, calipers etc.
Plan is for a full strip down and respray. Underside restoration. Possibly a new engine (£4500+delivery and fitment). Gearbox rebuild along with new clutch.
