Are there any Boot Dividers which fit the Yaris Cross?
Hi team Yaris Cross. Does anyone know if there are any boot dividers available for the Yaris Cross? Or if there are ones made for other makes which would fit the boot of a Yaris Cross?
Divide what?  My issue is stuff rolling from the upper deck through the gaps at either end.
Also stuff moving on the lower deck.  I use a no slip mat
There is a single deck board and a split one for the cross
58410-0D200, 58410-0D210 and 58410-0D230
the split board uses a support
58393-0D010
2021-Toyota-Yaris-Cross-GXL-Hybrid-boot-
Bob, don't think that is what Dave means.
On the Corolla, each side, were small, vertical removable panels that could stop stuff disappearing into the wheel bay.  Just before I sold it I discovered they could be raised and stop stuff falling off the upper deck.
On the YC stuff can drop through onto the lower deck :(.  Also stuff on the lower deck, like wheel nut box, first aid kit, warning triangle, can all slide around. I would find a tray useful there.
I find that split deck annoying too as I have the boot protector.  Raise half the deck and the protector tips stuff over, but that's just me.
Flash, it looks like any cargo strap could be used for heavy packages.  The tray OTOH appears to be just for an inflation kit etc.  If you have a spare wheel it is just using space.
With the AWD I only have the single level deck without the split. However, I did pick up the cargo net for the C-HR which help stop things sliding about. More details here:
Intrigued,
My Cross Net is 2 inches above the floor which disappoints slightly.
Please show me the image of the CHR net ?
Tel
In the linked thread. It does still float above the floor a little. Mostly due to the position of the anchor points.
Thank you.
Tel
The net is designed to hold a box with small items in it, Toyota of course make a very overpriced folding box - PW241-00000 £40-50
or you can get a bag/box for under £15 eg.
 https://www.amazon.co.uk/ZENO-Organiser-Collapsible-Compartment-Adjustable/dp/B0BQJS59C4
https://www.amazon.co.uk/Uoking-Organizer-Mini-Van-Collapsible-Portable/dp/B0999D362Q/
I picked up the expensive Toyota box for £40. It does seem to be well made. The £15 Amazon ones had few and slightly mixed reviews.
That box isn't too bad for a Toyota accessory; My friend was quoted £300 for a deckboard! :laugh:
