Oil Filter Wrench for toyota corolla E15 2010 1.6L
Hello
I would like to have some advice about what oil filter wrench I should buy for my toyota corolla E15 2010 1.6L.
Can I use the wrench of the 1.8L? Are they the same?
Kind regards
Timo
you can buy anything like that or similar however here it’s  important to note that the outside diameter should not be larger than 80mm, there are some socket’s between 78-80mm, those fit and some that are 84mm and those doesn’t. https://www.ebay.co.uk/itm/334770819720?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=zing7pkkqhw&sssrc=2349624&ssuid=p34UK1z2T4m&var=&widget_ver=artemis&media=COPY
1 hour ago, TonyHSD said:
Thank you very much! Very appreciated!
You are welcome 👍
