Oil o-ring and drain plug bolt for toyota corolla E15 2010
Hello everyone
Could someone tell me the OEM code (or link me) of the oil o-ring/gasket and oil drain plug bolt for my toyota corolla E15 2010 1.6L?
Kind regards
Timo
you can use this website https://japancars.ru/index.php?route=catalog/toyot to located your car and engine, then search for parts and original numbers then in eBay, Amazon for shopping. These plug and washer are standard for most Toyota models and widely available, you can also buy from local dealers too. The oil filter comes with rubber seal and it’s important to install it correctly in the specific groove without been twisted too much and add an oil film around.
My local dealer asked me 15 euro for 1 plug and gasket... And Thank you very much for the link! This will help me  tremendously  in the future if I need to find orginal parts!!!
1 hour ago, ToyotaLover39 said:
https://japancars.ru/index.php?route=catalog/toyota&mdf_id=11632&vin=AHTLH56E903052704&area=EU&cat=164510&blk_id=1105
When you look at the gasket section I see 4 different OEM numbers. What's the reason for it?
Sometimes they have older number replaced by newer one. Here is plug washer 90430-12031, you can buy bulk non original but remember they are softer and you need to torque them less, perhaps around 30-35Nm max. And oil filter is max 25Nm which is as soon as stops rotating.
Here is the plug number 90341-12012.
Ok thank you again for the respond!
You are welcome. 👍
