Hi All
I have a 2014 corolla saloon , lately the seatbelt alarm keeps ringing when no one is in seat , any fixes ?
A bag on the seat maybe?
You could fasten the belt if that's convenient.
Hi John,
Apart from the suggestion above and possible faulty sensor of loose connector under seat.
Not sure if this will work on your 2014 car but give it a try, this post goes some way to stop it.
Here is your solution to the annoying seatbelt alarm (works on all Toyotas, I used it on my 2005 Corolla and yes, I always use my seatbelt):
(1) Turn the Car "ON," but do not start the engine (leave your foot off the brake, don't fasten seatbelt). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds. (2) Make sure your seat belt is not fastened. (3) Turn the ignition back on, do not start the car (leave your foot off the break, don't fasten seat belt). As soon as you see everything light up, press and hold the trip reset knob and do a long
12 second count. (4) Keep your finger on the trip reset knob. Fasten your seat belt. As soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on." At that time, take your finger off the trip reset knob and it should cycle to "b-off." If it doesn't, just press the knob again until "b-off" appears. Once "b-off" appears, turn the ignition off and unfasten your seat belt. Now, when you start your car, you should hear the "normal" seatbelt beeping, then when you go over 10 mph, if your seatbelt is not fastened, it won't beep 54 times... the seatbelt signal will just continue to flash... but no more annoying beep!!.👍
Quote
No bag on seat , and can't leave belts fastened unfortunately.  Will give the ODO procedure a go and see what happens .
Thanks for yer help.
