OBD Scanner for Toyota HiAce
generaljohn
Can anyone recommend a scanner that works with a touring hiace 2002 has I have purchased three so far and not one has can be recognised. Thank you in advance
It's diesel I take it, diesels before 2003-2005 are obd2 but not fully compliant most use K-line - what readers have you tried ?
hi thank you for the the quick response
petrol 2.7 with lpg conversion
have tried
Autel universal nt500
Obdstar x-100 pros
Super k+can
Geniscan gs400
Without any luck
Do they connect or attempt to connect ? or don't they power up
Quote
do you mean a Foxwell NT500 if so that is a VAG tool
X100 is a key programmer
Super K+CAN is another VAG tool
Geniscan gs400 - this is a can bus only tool
All power up
Then can't find anything
Kind regards
John
  • 11 months later...
I know this is an old thread but did you find one that worked?
2002 should be OBD2 if it's not a diesel, if it's a jdm van it may be JODB
You can still do a paperclip test (link 2 pins and count the flashes)
earlier cars used the 23-pin diagnostics (obd1)
  • 4 weeks later...
I used a Topdon Artilink 600 to diagnose failed ABS sensor on the front  right wheel, not many do body and ABS diagnostic but I tested the sensor with a meter and it was indeed faulty. So far nice unit.
