Can anyone please help with wiring data for the start/stop function switch on MkII Aygo?
I've recently bought a 2021 C1 (Aygo MkII clone) which is fitted with engine start/stop. I really don't like start/stop.  In Thailand I have a 2022 Yaris Ativ with S/S and I was able to disable the S/S function by fitting a small length of aftermarket harness between the switch and the main loom (see image below). The aftermarket harness appears to contain a capacitor which 'pulses' the S/S switch line every time the ignition is turned on. This mimics pressing the switch and so turns off S/S every time I start the car. I want to do something similar with the C1 but I need to know the connections.
it's a ground side switch - violet pin 6 White/black pin 3
Pin 1 is on the right as viewed from the wire side of the connector/ rear of the switch
please let us know the outcome
Big thanks! I should be able to sort something out - I'll report back in a couple of months.
