HI All, I own a 2021 Toyota Corolla Excel Hev Cvt Tourer, I have recently exported the car to france, and need to swop around the fog light from the right rear cluster to the left rear cluster for the car to be compliant under D.R.E.A.L (UK version of VOSA). Ive popped the trim on the rear door and greated with a mass of wires. From look at the cluster the rear Fog is the pretty much in the centre of the right hand side cluster. I dont want to go the the exense of swopping the cluster ( Beside I am not confident enought to  try), Had a scout aroud tin ter net, but only coming up with american manuals for previous models and cannot find anything on you tube.
Would any of my new friends out there share some guidance, help, assistance...
Thanks in Advance
its just a case of swapping sides and using a red bulb
Can you give me a bit more on that?, I presume its prewired
There are 2 different versions, I think it will be a sealed led unit on a 21 plate, if so you need to replace the unit
i will have to look at some part numbers
I could be wrong but I think they are soldered leds, no bulbs to change!
On UK cars the RHR inner lamp has a Red LED for rear fog and the left has a White LED for reverse the bulbs are serviceable but I cannot say if they can easily swapped side to side, if they can you will have to do some wiring extension ( e.g cut RH fog bulb plug off with a tail of wiring and add sufficient wire to reach the left lamp) to run the fog harness/plug left and reverse the opposite,or trace the wires from each bulb to there common plug and re-pin the plug, otherwise:
LH lamp for LHD 81591-02C60 £220.39 + vat
RH lamp for LHD 81581-02C60 £220.39 + vat
