Has anyone experienced any leaks around the boot seals? I've been out to the car and the top left of the headliner in the boot is wet and the carpet below is saturated.
Looks like it's coming around the seal but can't see anything obviously wrong.
This is on a 21 TS
if I remember correctly there were some similar topics. Perhaps if you use Google search and type Corolla hybrid roof leak, antenna leak, interior leak anything similar might pop up some results. And again on a recent car best to let the dealer fix it under warranty.
Good luck
No known leak issues there has however been a recent TSB concerning water from "Roof panel" condensation;
BO-00921T-TME
Subject: Water condensation on roof panel
Area of Application: All Markets
Models – Model Codes: Corolla - MZEA11, MZEH12, MZEH19, NRE210, ZRE210, ZRE212, ZWE211, ZWE213, ZWE219
Description of the phenomenon
Some customers may experience and report about wet spots on the roof headlining or multiple warning lights on combimeter (caused by moisture in tail gate wire harness connector).
In specific conditions the humid air inside the vehicle may condensate into water on the inside of the roof panel. The condensed water droplets may run down onto the interior parts and cause visible wet spots.
Repair is to remove existing roof panel insulation and fit a new design covering more of the roof inner panel
Thanks for the info @Devon Aygocar is booked on on Friday, hopefully it can be resolved fairly quickly
