Number plate holder
Newbie47
Has anyone changed the plates on their Yaris using a plate holder? If so did you just use the 2 screws on the front or as it’s slightly curved did you also put sticky pads (or similar) on the ends of the holder?
Thanks in advance
Thanks in advance
You have practically answered the question yourself. I would use the same fixing screws and holes. If not happy then use the sticky pads as necessary.
As Bernard says, I would also use the two fixing screws
