Airbag safety light
Steph Warren
I have a Toyota Yaris with an annoying airbag indicator light permanently on. The engineers' diagnostics advised that the squib/clockspring was faulty; so I replaced it, but still the light is on? Any clues/feedback/suggestions very gratefully received.  Thank you Steph
Throw it back at them as unsatisfactory repair!
Having an airbag light = dangerous to drive.
Is this a recent purchase and/or have you been servicing it at Toyota?
Air bag light is an MOT fail and is something that should be fixed under any existing warranties on the car.
Hi Steph. Your post says you replaced it. Just to clarify, when you say you replaced it, did you do it yourself, or did you get someone to do it for your (i.e., you local mechanic). If you did it yourself, did you clear any codes stored in the vehicle. If a local mechanic did it, same question plus do what @YarisHybrid2016 says and return it to them as an unsatisfactory repair
What was the fault code when read?
