IQ3 Dash lights on.
When I switch off my engine and get then lock the doors by either using the fob or touching the door handle most
of my dash lights stay on including the mileometer side but the speedo and rev binnacle lights go off. I'm now worried
about coming back to the car to find a flat Battery.
Can anyone advise or help me please.
kind regards
Chris
  • Sad 1
A known issue on 1.33 engine with stop start see:
For an IQ you will need
Thank you Devon Aygo for your quick and helpful reply, I will order the parts today, could you tell me,
when I lift the bonnet is it obvious where the unit is or is it hidden under a cover?
kind regards
Chris
kind regards
Chris
No problem its on top of the gearbox under the Battery tray to access, remove Battery then Battery tray
Thank you again Devon Aygo, helpful knowlegeable contributers like you really make
this forum what it is, brilliant 😁
kind regards
Chris
Toyota says earliest delivery is 3rd April 🤫 so a bit of a wait,
just a note to anyone else who might suffer this, the Battery does go flat
in 36 hrs.
kind regards
Chris
I've just phoned the local Toyota dealer and they now tell me it won't be April 3rd, it's now April 21st,
has anyone got a suggestion where else I can get this part. No G92C0-52050 ?
kind regards
Chris
Thank you flash22 for the tip, unfortunately they have given me the same approx date.
kind regards
Chris
stick a used part on in it till it comes into stock ? It should be G92C0-74021 (used part)
Thanks for that but I might have tracked one down from Toyota direct Parts. I put in the part number and it says
they've got one but it's listed for an Auris, so I've just emailed them to check it out,
 If no go I'll do what you suggested.
kind regards
Chris
that's the number i give you above, Fish Brothers is Toyota Direct Parts
You could ask @Parts-King aka Lindop Brothers
UPDATE.
After contacting companies that state online that they have this item in stock and then finding out , shall we say, ‘extending the truth’, I have decided to wait for my local Toyota dealer even though the date has gone back, and great thanks from the Toyota dealer in Swindon who explained the ordering system to me 👍.
The cheapest s/h part I could get was £70 !! So I have charged up the Battery, put it all back together and bought a NOCO GB40 starter £80. So all happy BUT since I’ve put it back together (didn’t unplug the eco box), it now sometimes flickers for a couple of seconds after switching off, mostly all dash lights go off straight away. Electrickery  is definitely stranger than friction 😂
So hopefully it will all be sorted by the end of the month and would just like to thank all the contributors to this saga.
kind regards
Chris
