Side mirror diagram for Toyota Aygo 2017
carllitos
Hi guys I'm hoping someone can help me with a cable diagram for the side mirrors and especially for the control panel.
Hopefully someone can help me out with this.
Thanks!!
  • 2 months later...
Yes just follow the diagram - take the mirror switch that is connector E9 each wire has its number this relates to the pinout of that connector
G4 is the connector for the doorpanel right? do you have the wiring diagram for that one?
G4 is the connector on the mirror, the pin numbers are on the diagram see page 3 for the connector
all these are connections for the mirrors but strangely I'm not seeing the connection that comes from the door panel
Not sure what you mean
A cable comes from the mirror down the door to a plug and socket into the main door loom, this feeds into the rubber door grommet and into the car and connects up to the main loom behind the kick panels
the mirror plug is just above the speaker, if fitted, if yours is a base car with no electric mirrors you will have to fit the door looms or add in the wiring
Yellow arrow is the speaker plug, the red arrow is the mirror plug
Sorry for the confusion, yes I have to fit the door looms or add in the wiring. but I need to know the wiring colors I'll check out the article you just sent me as well!
