4 minutes ago, Gray86 said:
And I now have a new drop link as well as shock absorber / strut (the mechanic broke the drop link when removing it, so had to order another). So with the stabiliser bar TSB, shock absorber & drop link guess what? STILL DOING IT 😩
what is left to be noisy? Can surely only be the strut top mount / bearing? Squeaky rattle over pronounced bumps in the road. Slight knock as well
Drive slow and stop sharply to make the front end deep down and if the squeaky noise comes up your next step is wd-40 silicone spray and give it a few pumps both side suspension arm rear bushes,  red arrows in the picture. You can spray some silicone spray even if the test does not show the noise and see what happens.
They are most common source of Toyota squeaky suspension noises.
  • Thanks 2
Good to know Tony ;-) I'll keep this info in my mind
Thanks Tony - will try it this week & report back
Tried this today to no avail. Booked in for 4th dealer visit on 16th June. Running out of options now with most things having been replaced
Thanks for the update. Hopefully you will find out soon and get it sorted. Meanwhile you can check same problem and solutions in American Prius gen 4 forums as these cars has similar or same suspension and likely to have similar issues and ways of fixing them published. 👍
Thanks Tony. Do you have a link to the forums?
EDIT: found Prius chat - lots to read on there!
  • 3 months later...
Well today was the day that my noisy suspension is finally sorted 🙌
after at least 5 visits to the dealer (who were helpful, patient & determined) we got to the bottom of it. The following parts were replaced in order:
visit 1: diagnostics
Visit 2: Anti roll bar bush (TSB)
visit 3: shock absorber (and drop link, as it broke)
visit 4: further diagnostics and investigation
visit 5: lower arm, then subframe and FINALLY - the strut top mount (the actual cause of the noise).
I dread to think of the warranty parts  & labour bill - inc alignment after subframe replacement. Safe to say both myself and dealership were relieved to fix it.
I did tell them early on that it was probably the top mount, but never mind. . .brand new suspension in that corner isn’t a bad thing.
  • 7 months later...
Hi all and especially Rado77 and Gray86,
I too have a knocking sound when driving over/down speedbumps (metllic or hard plastic like ticking souns). I already went twice to the dealership in an attempt to solve this issue under warrenty, they said they changed the 2 front stabilizer bar bushings, however noise is still here....I have seen the TSB in this topic (CP-00498T-TME) what will/must be replaced specifically herunder (only busching - or brackets and bolts al well?) It will go back to the dealership in the co ing weeks as the mechanic says new front shock absorbers will solve the issue.....
Thanks for the replies in advance:)!
Cheers,
Bob
Cheers,
Bob
Reading previous posts it seems like top mounts has sorted the issue.
I have sometimes slightly rattling noises from front going over road cracks but never bothered to change parts because not always present plus when car gets checked all seems rock solid. I know my reason for these noises , the squeaking noises goes away as I mentioned in previous posts, the rattling ones are from different parts but they never went worse to warrant any replacement. 👍
Thanks for the reply,
I was wondering what the TSB repair entails, just the bushings or bushings and brackets and bolts too?
Cheers,
Bob
I’m not often on here these days after selling my Corolla, but my top mount rattled on every bump on that side
My corolla does not rattle all the time, only intermittent clunck/sharp noise when suspension bottoms out so it seems...will go to dealer for now struts....next week..will see if that helps.
  • 5 weeks later...
Update: New struts/shockabsorbers on the front and still some unplaceable noise occasionally when the suspension bottoms out.......
Update: Problem solved!
I lifted up the car because was reluctant to drop the car off at the dealers for the 6th time. I noticed the strut dust cover was loose at the bottom on the driver side, I put I tyrap around the dust cover bottom to secure it to the strut base and the intermittend knocking sound has gone!!!
Unbelievable the dealer did not notice this and replaced both stabalizer bushings and front struts.
well done that man, you would think the main dealer could find a simple problem like that👹
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
