Hi I have a Corolla 2019 hatchback and am looking to buy an im4 golf buggy. The buggy would have to fit in the boot. Does anyone know if it fits? Height and width don’t seem to be a problem but length might be due to the slope of the boot door. Any advise greatly appreciated.
you have the numbers from the link above and you can double check for yourself. If your car has a raised boot floor, which is the must have addition you can fold one or both sides of the rear seats and this will give you an ample space and flat loading area. A hatchback that actually it is as practical as small estate.
image.thumb.jpeg.c693342557d4e73b2d38396d91fa209b.jpegimage.thumb.jpeg.8b144b008f051a96298cc5021e5140b8.jpeg
Thanks for your replies. The 2019 Corolla boot door slopes at a lower angle than Auris it replaced. Boot dimensions long enough but not sure there is enough height for the boot to close fully with the buggy inside. For example at 50 inches there is only 12 inches height with boot closed.
