O2 sensor replacement 2003 verso glx
rae Houghton
Under manifold cover Are 2 sensors. , Left and right.
Below are 2 sensers left and right.  Are the bottom ones post catalytic converter? And above pre?
I note cost differentiates between two. Just trying to figure what to order thanks
there might be bank 1 and bank 2 sensors and each to have pre and post catalytic converter so total 4
You will need to check your engine type and number of sensors. Here on this website you can find your car and locate parts and numbers. https://japancars.ru/index.php?route=catalog/toyota
Good luck
