2016 Yaris alloys fit MK2 2009 XP90?
keith_276
Hi, I have a 58 reg XP90 Yaris and had my alloys ruined by an idiot tyre fitter.
Can anyone tell me if alloys from a 2016 MK3 Yaris will fit on the MK2 please, as I'm having trouble understanding the offsets and so on.
Thanks in advance.
They should do, but im not sure on the offset on the Mk2
edit, pcd and centre bore are the same, the offset is in the same range 39-45 offset
Thanks. The offset for my 15"wheels on that site says 43-47, but it seems the alloys that I have a chance of purchasing from the facelift 2016 model have an offset of 37-41.
So I'm not sure if they will be ok or not.
Here is a photo of one of the wheels that I've been offered. The other photo shows the damage the tyre fitter done to my alloys (I don't have a photo of the full alloy just now)
That just the range, the mk3 uses a wider rim so the offset is different
Thanks very much for your help with this.
So these newer model 16" alloys should fit my XP90?
If you insert the wheels parameters of both cars on that website  you will be able to see exactly how they will seat on the car and by how much they will stay in or poke out and make your thoughts.
