After turning the hazard lights on while turning the car off to deliver something, i turned the car back on and found that the hazard lights wouldn’t turn off, the button was ineffective and now even when the car is off, the left side hazards remain on, however not flashing, just as solid yellow lights, i tried disconnecting the Battery and reconnecting it, removing and replacing the 10A fuse and disconnecting the hazard button, all to no avail. Any thought or ideas for a solution would be great.
I wonder if 2004 is old enough to use a blinker relay.
There will be I think a flasher and a indicator relay, if you find it remove it and give it a tap on the ground, l don't know if they still use contacts in them.
