2 Questions Bout My 2
just wondering can i clean my air filter? its not stock? if so hows the best way
how do i adjust my headlights so they shine higher more? not by using the control in the cockpit....my headlights shine really low to the ground.
Depending on what filter you have, try the K&N recharger kit..
To adjust your vertical beam.. pull up to a wall with your lights on, below your headlight you will find a small screw.. turning this adjustes the vertical aim but watch out.. dont want to blind all the oncomming drivers!
best to get your headlights alligned by a MOT station.
cheers guys, i think the filter is a k&n it was on when i got it. my bros mate has owns a mot garage, i'll use his lamp things to check it :thumbsup:
also get some brighter bulbs - they do make a big difference
