Yaris Cross - How to access windscreen spray tube?
VickiSarge
Visited Longleat on the weekend and stupidly thought the monkeys wouldn't damage my car - well guess what, they did. Ripped the spray nozzle clean off. As I was driving around I could see the tube poking out with water would just pump out of it.  Googled and it seems I can easily buy a replacement nozzle and fit myself.
Problem I now have is that the tube has fallen in and I can't seem to see it. Does anyone know how I can get access to this?
It seems like such a small problem to go to the garage for!
so the monkey were on top of the bonnet and were plying with the car? 🐒🙈
You are lucky if they did only that to your car  🫢
If they had taken the driver side nozzle then you can squeeze these two clips with yellow arrows and pull up the plastic trim which will give you access beneath the gutter and you might be a lot pull the plastic tube and fit a new nozzle. Before you start just unclip the rubber seal moving it to the side.
If it’s the passenger side then you might need to look for another place to access the tube.
Good luck 👍
