Any ideas what this bracket is called
Advance with a Avensis
What would you call the bracket which is held on by 4 bolts and is amost a triangle shape. It is for the o/s/f  subframe I believe, just behind the wheel arch. TOYOTA Avensis II Hatchback (T25) 1.8 (ZZT251_) Petrol 129 hp / 95 kW 2008 mo T3e2K3mTPyYlwUBITMByQb_sLymiw-3yskUVmaag
Subframe brace ?
official name is - Brace, Front Suspension Member, Rear
Many thanks if it helps anyone else Toyota Avansis has a part number 52257-05020 - BRACE, FRONT SUSPENSION MEMBER, REAR RH
