Problem with cooler water boils
Gregorys
Hi
I'm join the toyota club
I'm owner supra mk3
Looking for good understanding this generation car, mechanic what fix the problem.
Any water in the oil or oil in the water ?, start off with checking the water pump by taking the fan/aux belt off and feel the water pump for shaft play or bearing issues, maybe a hydrocarbon test to rule out a head gasket issue,
is that the 7M-GTE turbo ??
Yes, is Turbo 7M- GTE
I used this car year, more thousand  miles done, never problems. The seller said can be gasket problem  but I never put any water or oil, always checking  level, was good and oil clean. I pick my Supra from mechanic, was done service, oil, filters, cambelt , sparks  plugs  , first 3 miles after pick the car water from equalizing tank come out ..
Problem is, I do not know good mechanic  here, what you can trust  and he know what he do it..
Did they change the coolant ? If so, it may need burping to get the air out of the system - heater all the way to hot fan on full and run the car up to temp with the cap off
Does the radiator get hot, if not check the thermostat
iirc it runs a Viscous fan clutch, these can be prone to failure simply by taking it off the car
where are you in London
Hi
I'm close Heathrow,  West Drayton
My Whatsaap 07831243079
Yes, he changes the coolant but now I can't belive he done well with put the air out etc.
You have Supra or you had
It must be air locked, or the radiator has a blockage if it only has done it after being worked on - no supra, it's just basic engine mechanics
  • Sad 1
On 4/14/2023 at 8:33 PM, flash22 said:
Hi
I agree  but I not good with make anything myself , like we see standard engine  service  needs  good  as well,   lol.
How to check is the radiatior  blocked?
Thanks  for any reply
Ask around and find a good, local mechanic/garage that can help you. This is all standard stuff and you shouldn't need a Supra specialist.
Yes I know. I bought this Supra year ago, 3 weeks ago I done full service, oil, filters, spark plugs,  coolant  etc. Before the service was all great  and never problems,  after pick everything  not work like shoudl, that I not trust mechanic,  that why I needed  any help from someone  who know my area really  good garage.
If you changed the coolant yourself then remove filler cap start engine let it heat up keeping a eye out for air bubbles make sure heater control is on high set fan at low speed.
Press the lower radiator tube to help expell air locks and keep repeating it its a good idea to have a friend watching for air bubbles.
It may take 10 minuits after it heats up or 2 hours
Keep engine speed at tickover or just above but max 2000 rpm
I not changed myself,  the mechanic done everything,  then after everything is wrong, sometimes 1 cylinder is off as well, I don't want ho back this guy, that why I looking for good  understanding mechanic.
I'm Polish guy, can't really explain  my problem with the written.  Sorry
Guys, somebody here what live London area and can  recommend person what can do it the job with my car( maybe is more to do, I'm not sure about head gasket)
