Toyota Yaris 1.0 2012 Need help with audio system
Portugal
Good afternoon. Bought a car Toyota Yaris 1.0 2012. But there is a problem with the audio system. The maximum that I can achieve is what is in the photo. There is no book. It is necessary to change the screen, it almost does not respond to touch, but I do not know the model number of the system. And I don't know the screen number. I understand that there is an old system and it is not when it is not updated. But since the screen does not respond to touch, I can not find out either the firmware number or the model number. Can you suggest what can be done in this situation.
B1585 is a usb fault
U0100 is a can bus no comm
U0129 Lost comm with ABS
check the usb port in the glove box and make sure there is nothing jammed in it or any bent/missing pins
Edit. Its a Touch system - if it has nav, it will be a Touch and Go
There is navigation, but the maps are not installed. I can't do anything. The touch screen needs to be replaced first. but I don't know the serial number.
If you press the nav button and it says "Navigation is not available on this system" you do not have navigation
if it does have nav but has failed it can lock up the display - pull the unit out and have a look, post a pic if you are unsure
mk3 stereo removal - Copy.pdf
not installed. when I click on the button, a message appears that the system is not installed
I would first replace the touch screen. how can i find the serial number? There are many on sale, but they are slightly different, I don’t want to buy the wrong one.
The part number is on top of the unit, it will be something like 86140-0D010 or 86140-0D030 (LHD)
