Sun visor too short?
My sister complains that her 2023 C-HR's sun visor is too short, and basically can't block any sun whatsoever, It's wide enough, It's just not tall enough,meaning it doesn't come down far enough when you fold it down. Does anyone have any ideas about extenders for these that are solid, not the see-through kind she doesn't want those, but an easy to install extender that makes the visor taller so to speak, up and down.
Thanks for any and all ideas.
That's a bit funny as mine has the opposite problem - It 'locks' in on 3 positions because of the springy electrical contacts, so it's either full 90 degrees down, which completely blocks my forward view, or horizontal, which means it only shields against the sun if it's high in the sky :laugh:
Any attempts to put it in any other position just means it'll snap back down, narrowly avoiding hitting me in the face! :eek:
There seem to be a lot of things like this on Amazon to solve your problem tho':
https://www.amazon.co.uk/TFY-Extender-Anti-Glare-Windshield-Sunshade/dp/B08FHZ8TLV/
https://www.amazon.co.uk/WANPOOL-Sunshade-Anti-glare-Extender-Passenger/dp/B07JM2QKMQ/
https://www.amazon.co.uk/Extender-Universal-Extension-Adjustable-extension/dp/B0BR5P64BS/
Try raising the seat height.
Try lowering the roof.
Haha, that’s funny 😄. I always have the op problems 🫢 in any car. I believe it’s because of drivers height and seat height adjustment. I am on the shorter side and I do like to seat a bit lower than usual as this is the more comfy position in any Toyota car for me. Toyota seats when adjusting up or down you are actually adjusting the leg angle too and your back support, rear end of the seat cushion. 👍
