Hot starting
Glen marriott
Hi I’ve got a 53 plate rav 4 good on cold start but will intermittently not start when hot any help will be appreciated thanks
glen
what engine and mileage is the car? There could be many possibilities. Fuel pump, filter, sensors, vacuum hoses, diagnostic is the first step.
Hi - I had this problem a couple of years ago and fixed it (eventually). I've posted on a likely fix several times so do do quick search and you'll no doubt find my suggestions - but start with cleaning the earth wires (there are two) to the engine block.
