Oil in Cooling liquid - Toyota Camry 2.0 GLi Kat
Alpenflitzer
Motor Nr.3s-561201                Fahrgest.nr. JT1 EOSV 21 00148 191
Anyone an idea  what the repair could cost in the repair shop oder how long it takes if I change lthe cylinder head seal and clean the cooling area from oil?
Thanks for your help.
You have to take the head to the machine shop . Have it ground down “if it can be “ and pressure tested. They should have it done in 1 day. Hopefully they can talk you it’s reparable.
