Hi all
I'm looking for the pinout of the oem toyota radio in a verso
Type b9002
I want to connect the camera to my android radio
This is a 10pin out but I only need the back camera to bo connected
Someone please???
Have another look, you should have a 24 pin and/or a 20 pin the 10 pin is for the cd changer
please see this thread, what was updated today
No, because I re connect the old head unit and put it in reverse En romoved the white 10pin plug and the camera shuts off and when I put it in the camera work again
It's the video/Com pin the other are for the speakers
oh it's an ancient one
you will have to give me a day or so
Yeah thnx
Well that got complex really fast
The camera is run by a camera ecu what is under the passenger seat (driver's seat on a LHD) the 10 pin is for the camera but is RGB and sync NOT composite, the camera ecu is controlled over AVC-LAN by the oem radio/nav
The good news is the camera is standard composite and 6v you will need to wire it from under the front seat to the radio
Wauw, so there is no chance that I can take the wiring from the 10pin connector to the android radio? Correct me If I'm wrong...
No, the wiring is only under front seat, you could link it through to the radio
10 Pin
1 - VR
2 - Red (video)
3 - Blue (video)
4 -
5 - TX+ (avc-lan)
6 - VG
7 - Green (video)
8 - Sync (video)
9 -
10 - TX- (avc-lan)
You are the best, nou I'm gonne figure out which one is from. The back camera en Connect them to my android radio
None of them on the 10 pin are from the camera(s) that goes directly to the camera ecu only
the camera signal is fed in to the camera ecu - it then is processed and sent to the radio over RGB and Sync the ecu is controlled by the radio over the TX+ and TX- avc lan
there is no direct camera connection on that 10 pin connector !!!
Hmmm OK.  So or the best thing connect a new camera.
Or search for the correct cables from the camera ecu
Yay, the camera connections are on the 40 pin camera ecu plug
you can either cut and join the wires or link the pins (camera ecu unpluged of course) so you can wire it behind the radio
I do have those pin outs
Ik thats nice, can you send me those
Then I can look what I'm going to do.
I have a cable for the android radio that I need to use
this is view is the front of the connector
19 - Ground (yellow)
20 - 6v+ (black)
39 - Video - (shield)
40 - Video + (blue)
wire colours may differ
Yeah I think I'm going to connect te "new" camera to the android radio.
Because the connector that I bought has an rca plug
And I really don't want to cut or rewire from the Ecu of the camera
