Aygo 2007 could anyone check cps resistance values to ground
2 hours ago, flash22 said:
It's that OCV, try another one
Got my hands on the original ocv and getting same code, same probs and if I connecting to 12V engine stumbles, so now it cant be the ocv.
  • Replies 64
  • Created
  • Last Reply
Top Posters In This Topic
  • niceone
    37
  • flash22
    28
Posted Images
If that is the case, it's a cam timing issue, the chain is in the correct position but the cam in relation to the VVT is not
the exhaust cam is in a fixed position in relation to the chain, but the intake can be advanced or retarded by 10º by means of oil pressure what is controlled by the OCV
remove the chain and re time it to the letter of the instructions
The manual never says to adjust the cam when timing the engine. It can be adjusted by the ecu anyways.
It does
put the chain on with the engine set correctly, rotate the intake cam counterclockwise to put the slack on the tensioner side, do 2 full rotations, check the exhaust cam pulley markings to the markings on the head, then release the tensioner
directly from the service manual
1kr INSTALL CHAIN SUB.doc
It does
All of this is about tension and my tension was tight, I dont think the manual means to !Removed! or to advance the camgear all it says is to put the slack on the left side where tensioner is and thats what I did before.
Did you replace the VVT pulley when you "rebuilt" the engine ? What was the reason for rebuilding it ? New chain and sprockets or the old, original ones ?
The inlet cam is in the wrong position, only thing it can be is a bad VVT pulley
I didnt replace the pulley. I rebuilt it to switch the crankshaft. The chain and sprockets are old ones. I changed out the ECU and same stuff still happens. Idk maby it is the pulley that worked pre rebuild...
What year was the crank from ? Did you confirm TDC of piston No. 1 via the spark plug hole rather than just the marks
Its from 2014 but it looked identical. I did confirm the tdc of piston nr1.
Is that a mk1 or mk2 aygo ?
Mine is mk1 and the crankshaft I think is from an mk2, but as I said are identical.
the mk2 does have a different compression ratio
everything points to a stuck/faulty VVT gear/pulley
Took the vvt gear out and didnt see anything bad, the locking pin moves up and down easilly.
Are the internal passages clean, do you have the spring, are the passages clear in the cam
I have the spring on the pin. If the passages were not clean they will sure be now, even though didnt seem clogged
It wouldn't hurt to clean them out it only takes a bit of gunge to foul an oil way or valve
Ok so I've finnaly put it back together and I've checked the timing by removing the whole cover and all was still fine and still gatetting the same code.
the mk2 crank sensor is different to the mk1, only thing I can think of is the reluctor ring on the crank is different
what does the ocv filter look like
The rings are idenical and the filter is alright, maby its the crank sensor
I don't think it is the crank sensor, replace the VVT pulley it may have a mechanical fault when under oil pressure
Ok I think Ive fixed it by adjusting the timing, not sure yet since now I have another problem. The car starts then dies, and there is much fuel, the cylinders are wet, there is spark, but it just always runs for a few seconds then dies, tried to reset immobilizer. Not getting p0011 code or any code anymore.
Check the earth point on the right side of the head 2 wires 1 white/black and the other is brown
All is good there no rust. The color of the spark is orange, hopefully that's OK.
Orange ? Clean and gap the plugs, IIRC it should be 1.1mm
sounds like you still have it timed wrong or the reluctor on that Mk2 crank is in the wrong position, there are 3 different cranks and 2 different sensors for the Mk2
the crank chain sprocket may be different in relation to the marks on the engine find TDC on no.1 cylinder preferably with a DTI gauge and see where the marks are
If I have no code anymore does this mean my timing is correct?
