2022 corolla
does anyone have or can locate the repair manuals which include the panel alignment gaps (to the mm)
door was replaced (minor incident, no damage besides small dent on door sheet, they used the excel door with increased sound deadening, was thinking of replacing the other side door but too expensive and too much hassle) but the panel gaps are out, from the front fender, to the back door are all out very slightly.
it’s causing higher wind noise on the motorway and changed the pitch which I’m finding annoying.
i don’t think it would be wise to adjust myself but does anyone have or can obtain the specs please?
Suggest a return to the body shop.  Tell them the problem.
One tip, don't watch them fix it.  I had a car that howled at speeds above 30.  The fix took a minute.  I just wish I had not seen it.
