clutch
That's right. It was updated to the stronger Yaris clutch because of premature wear.
I was aware of the 180mm updated to 190mm but not the 200mm
I also looked at the Yaris and they quote 190mm very confusing.
The Mk2 (2014 on)  clutch is uprated/bigger again , to about 200mm iirc, as mentioned the Mk1 (2005-2014) clutch went from 180mm to 190mm about 2009. So your findings sound about right.
Its 200mm on the KGB40 there are some major changes to the Mk2 aygo
go with a LUK or if on a Budget look for sachs (3 piece clutch kit)
https://aftermarket.schaeffler.com/en/catalog/auto-parts/clutch-attachment-parts/clutch-kit/clutch-kit-luk-repset/p-TA-479-6203357000/v-TA-105577
if you are paying a garage to do the work let them supply and fit, then they are liable if anything goes wrong, if you have a problem you may find yourself having to pay the labour again if you supply the parts
Thank you very much for your reply I agree with your comment about garage fitting.
Thanks for your reply.
