Exhaust sensors Dpf
gsk
Hi all I have a 2010 Toyota rav 4 D  2.2 2010 model 72,000 miles, I have been told by garage that it has 5 exhaust sensors, and two are faulty due to engine warning lights on the garage suspect Dpf fault, does this make sense to anyone else please
Many Thanks Gary
What codes do you have ? 2 readings are done by 1 sensor - differential pressure sensor this monitors the pressure either side of the DPF it then calculates when it needs to do a DPF regen (burning off the particulates and Clearing the DPF)
low mileage and short runs are a killer for a car with a DPF
